Scheduling AP CLI Scripts
You can upload AP CLI Scripts to be run on APs within selected zones. You can also schedule the script to be run on the APs at a particular time or when the AP joins the zone.
  1. Go to Administration > Diagnostics > Scripts.
  2. Select the AP CLI Scripts tab.
  3. From the domain tree, choose the domain in which the AP is present.
  4. Select the script from the list of scripts in the AP CLI Scripts table.
  5. Click Schedule.
    The Schedule Script page appears.
    Figure 207  Scheduling scripts
  6. Configure the following:
    • Execute on a Schedule: Enable this option to execute the script based on the current system time which is displayed.
    • Interval: select the time interval within which you want to schedule the execution. Options include Daily, Weekly and Monthly.
    • Time: from the drop-down menu, select te hours and minute when the script must be executed
    • AP Joins the Zone: enabling this will ensure the script is run on the AP when it joins a particular zone.
  7. To select the zone, click Select.
    The Select Zone page appears. Identify and select the zone. The selected zone is populated in the Selected area.
  8. Click OK.
The schedule is configured and the script will run on the AP as planned.
