You can approve mesh APs that join the network using wireless connection.
Go to the Access Points page. On the upper-right corner of the page, select the
Mesh option from
View Mode.
The mesh APs are listed. The
Mesh Role field, displays the status of the APs.
To view the list of APs pending for approval, click the
Unapproved APs below the left pane.
From the list, select the AP which is not assigned to a Staging Zone and click
Approve.
The
Approve Mesh AP form appears.
From the
AP Zone drop-down, select the zone.
In
Last 4 digit of AP S/N, enter the last four digit serial number of the AP.
Click
Approve, to manually approve the APs that join the network using Zero Touch Mesh (ZTM).
After approval, Zero Touch Mesh (ZTM) AP changes mesh role to “approved”, and the AP will show up in AP list for waiting AP join.
