Unblocking a Wireless Client
If you want to allow a client that you previously blocked to access the SmartZone network, you can unblock it.
Follow these steps to unblock a wireless client.
  1. On the menu, click Services and Profiles > Access Control.
  2. Click the Blocked Client tab.
  3. From the list of blocked clients, locate the client that you want to unblock. If you have a large number of blocked clients and you know the MAC address of the client, enter the MAC address in the search box, and then press <Enter> to search for the client.
  4. When you have located the client, select it, and then click the Delete button above the table. The table refreshes, and then the client that you want to unblock disappears from the list.
You have completed unblocking a wireless client.
