Web Interface Features
The web interface is the primary graphical front end for the controller and is the primary interface
You can use it to:
- Manage access points and WLANs
- Create and manage users and roles
- Monitor wireless clients, managed devices, and rogue access points
- View alarms, events, and administrator activity
- Generate reports
- Perform administrative tasks, including backing up and restoring system configuration, upgrading the cluster, downloading support , performing system diagnostic tests, viewing the status of controller processes, and uploading additional licenses (among others)
Figure 1
Controller Web Interface Features
The following table describes the web interface features.
Feature | Description | Action |
Main Menu | Lists the menus for administrative task. | Select the required menu and sub-menu. |
Tab Page | Displays the options specific to the selected menu. | Select the required tab page. |
Content Area | Displays tables, forms, and information specific to the selected menu and tab page. | View the tables, forms and information specific to the selected menu, sub-menu and tab page. Double-click an object or profile in a table, for example: a WLAN, to edit the settings. |
Header Bar | Displays information specific to the web interface. | Select the required option (from left to right):
You can also use the
icon to expand and shrink the main menu. Shrinking the main menu increases the size of the content area for better readability and viewing.
