Disconnecting the Switch Connection with SmartZone
The sz disconnect command can be used to disconnect the ICX switch from the current connection with SmartZone and initiate a new connection based on the currently available list of SmartZone IP addresses.
Enter the
sz disconnect.
This command can be executed on the local terminal.
ICX# sz disconnect SZ Disconnect initiated...
