Configuring AP Settings
- Approving APs
APs must be approved to join the system. - Working with AP Registration Rules
Registration rules enable the controller to assign an AP to an AP zone automatically based on the rule that the AP matches. - Tagging Critical APs
A critical AP is an AP that exceeds the daily traffic threshold (sum of uplink and downlink) data bytes configured on the controller web interface. - Configuring the Tunnel UDP Port
The tunnel UDP port is used by all GRE+UDP type tunnels. - Setting the Country Code
Different countries follow different regulations for radio channel usage.
