Changing the Zone's AP Firmware Version
The controller supports multiple firmware version. You can manually upgrade or downgrade the zone's AP firmware version.
Follow these steps to change the zone's AP firmware version:
  1. From the Access Pointss page, locate the zone for which you want to upgrade the AP firmware version.
  2. Click More and select Change AP Firmware, the Change AP Firmware dialog box appears.
  3. The Current AP Firmware version is displayed. Select the firmware version you need. If you upgrade to a new firmware, a backup configuration file will be created. You can use this backup file to downgrade to original firmware.
  4. Click Yes, a confirmation message appears stating that the firmware version was updated successfully.
  5. Click OK. You have completed upgrading the zone's AP firmware version.
