Complete the following steps to configure a split tunnel profile:
Select
Select the
Split Tunnel tab, and then select the zone for which you want to create the profile.
Click
Create.
The
Create Split Tunnel Profile window is displayed.
Figure 189
Creating a Split Tunnel Profile
Enter the split tunnel profile information:
RuckusGRE or SoftGRE must be enabled on the WLAN before mapping it to a Split Tunnel Profile.
- In the
Name field, type a name for the split tunnel profile.
- In the
Description field, type a short description for the split tunnel profile.
- In the
IP Address field, enter the destination IP address.
- In the
Subnet Mask field, enter the destination IP subnet mask.
- Click
Add to add the destination IP details.
- Click
OK.
You can also edit, clone or delete the profile by selecting the options
Configure,
Clone, and
Delete respectively from the
Split Tunnel tab.
