You can move the switches within any group or sub-group within the system hierarchy to manage it.
From the left pane, select
Switches.
The
ICX Switches page appears.
From the
ICX Switches page, select the switch that you want to move and click
Move.
Figure 58
Moving the switch
The
Select Destination Switch Group page appears. It displays the system hierarchy from which you can select the group under which you want to move the switch.
