By default, the controller saves a record of all events that occur to its database. You can configure the controller to also send SNMP traps and email notifications for specific events whenever they occur.
Verify that global SNMP traps are enabled to ensure that the controller can send SNMP traps for alarms.
You can also manage notifications of the event for each zone by clicking the zones displayed in the tree structure. Event configuration for each zone is independent including:
- Enabling or disabling E-mail notification settings
- Recipient E-mail address
- Enabling or disabling DB persistence settings
- Enabling or disabling SNMP trap settings
You can also manually trigger SNMP traps without generating events using CLI. You can use the
#trigger-trap <event code> command to trigger traps for respective events with their default attributes.
You can acquire the status of a specific client MAC address by using the query RUCKUS-CTRL-MIB. For more information, see the
SmartZone SNMP MIB Reference Guide.
Go to
Click the
Event Management tab.
The
Event Management page appears displaying the following information:
- Email Notification: Select the
Enable check box, and then type an email address or email addresses in the
Mail To box. If you want to send notifications to multiple recipients, use a comma to separate the email addresses. Then, click
OK.
- Events: View the table and select the events for which you want to send traps or email notifications (or both). Select the
Enable or
Disable options from the drop-down menu, and configure the following:
- Enable SNMP Notification: Click this link to enable SNMP trap notifications for all selected events.
- Enable Email: Click this link to enable email notifications for all selected events.
- Enable DB Persistence: Click this link to enable saving of all selected events to the controller database. If an event is already currently enabled, it will stay enabled after you click this link.
Following information related to the event are displayed:
- Code: displays the event code.
- Severity: displays the severity of the event such as Information, Minor and so on.
- Category: displays the category under which the event falls under, such as AP communication.
- Type: displays the event type such as AP managed, Ap rejected and so on.
- Zone Override: display the override status of the zone.
