Copying Switch Configuration
You can copy the configuration settings from a working switch to one or multiple new switches.
  2. Select the switch group and then the Configuration tab.
    Figure 69  ICX Switch Group Configuration Tab
  3. Click Copy Configuration To and select the switch or group to which you want to copy the configuration profile, and click OK.
  4. Click Get Configuration From and select the switch or group from which you want to get the configuration profile, and click OK.
