Setting up switch registrar discovery
The switch registrar is a Ruckus-hosted cloud service that enables SmartZone discovery from ICX devices.
You can configure the ICX device to retrieve the correct SmartZone management IP address or address set from the switch registrar. The switch registrar must be set up in advance via Managed Service Provider (MSP) with SmartZone IP addresses and the ICX serial numbers they can manage.
How switch registrar discovery works
The ICX device sends an HTTP GET message to a default server host, sw-registrar.ruckuswireless.com, for the list of SmartZone management IP addresses, unless the system administrator configures an alternate host. The SmartZone IP address obtained in response to the GET is used to query the SmartZone device to set up a connection. If the ICX device receives a set of IP addresses from the switch registrar, it stores them and tries them in turn until a successful connection is established with the SmartZone device. The IP address or set of addresses obtained through the switch registrar is given priority above all other addresses in the list of SmartZone IP addresses, including addresses received from other sources such as the DHCP list, the active list, and the passive list. Once the ICX device has obtained a SmartZone IP address from the switch registrar, it no longer attempts switch registrar discovery.
This query is performed only for greenfield deployments and when the ICX device boots up with no startup configuration. ICX switches being upgraded from older releases that already have configuration in place will not have the registrar-based SmartZone discovery turned ON. The HTTPS session used for the DB query uses the device certificate installed on the switch for SSL session establishment. For the initial release of the switch registrar feature, no server certificate validation will be performed.
Disabling or enabling switch registrar discovery
ICX# configure terminal ICX(config)# no sz registrar ICX(config)# write memory
- sz registrar-query-restart
- sz reset
To enable switch registrar discovery on an alternate registrar host server and save the entry to startup configuration.
ICX# configure terminal ICX(config)# sz registrar host_name ICX(config)# write memory
Confirming successful switch registrar discovery
For log entries specific to registrar queries, use the show sz log command.
Aug 8 21:47:17:I:SZAgent: SZ Switch Registrar Query to 54.186.143.194 Success
Aug 8 21:47:17:I:SZAgent: Disconnect to SZ: 54.16.143.194, Got SZ ip via registrar
You can use the show running-config command to check for the name of the registrar host and the registrar-list of SmartZone IP addresses.
ICX# show running-config ! ! sz registrar sz registrar-list 23.251.150.119 ! !
ICX# show sz status ============ SZ Agent State Info =================== Config Status: None Operation Status: Enabled State: SZ SSH CONNECTING Prev State: INIT Event: NONE SWR List : 23.251.150.119 Active List : None DHCP Option 43 : No DHCP Opt 43 List : None Passive List : None Merged List : 23.251.150.119 Merged Idx: 0 IP : 23.251.150.119 Switch registrar host : sw-registrar.ruckuswireless.com
Troubleshooting switch registrar discovery
- The running configuration contains "sz disable".
- The switch registrar is not configured on the ICX device.
- The DNS configuration needed to resolve the switch registrar address is not present on the ICX device.
- The ICX device could not reach the switch registrar due to routing issues.
