Exporting Zone Templates
You can export a zone template.
To export a zone template:
  1. From the application select, System > Templates > Zone Templates.
  2. Select the zone template that you want to export and click Export Template.
  3. A pop-up appears prompting you to Open or Save the zone template file with .bak extension. Click:
    • Open—To view the template file
    • Save—Select the destination folder where you want to save the template file and then click Open to view it.
