Creating a Traffic Class Profile
To create a traffic class profile, you must define the basic required settings.
  2. Select the Traffic Classes tab, and then select the zone for which you want to create the profile.
  3. Click Create.
    The Create Traffic Class Profile page appears.
    Figure 156  Creating a Traffic Class Profile
  4. Under General Options, enter traffic class profile name and description.
  5. Under Traffic Classes, click Create to add a traffic class.
    Only four traffic classes can be added in a single Traffic Class profile.
    The Traffic Class page appears.
    Figure 157  Creating a Traffic Class
  6. Enter the name of the traffic class profile.
  7. In the Access Control Rule Entry field, enter an access control rule in the proper format.
  8. Click Add to add an access control rule or click Import CSV to import an access control list.
    Click the Import CSV arrow and select Download Sample (CSV) to download the CSV template.
    To delete an access control rule, select an entry and click Delete.
  9. Click OK.
You have created a Traffic Class Profile.
IP destination is reachable only when IP is not part of Traffic Class, but present under Split Tunnel. Split-tunnel policy is effective only when both Split Tunnel and Traffic Class features are enabled together.
