SmartZone provides an option to define LAGs at an individual switch level.
From the
LAG Setting, click
Create to view the LAG settings.
The
Create LAG page is displayed.
Enter the following settings:
- LAG Name: Enter a name.
- Type: Select either
Static or
Dynamic from the list.
- Selected Port: You can select multiple port numbers from the list.
Click
OK to apply the LAG configuration onto the selected switch.
