SCI Thresholds for each AP
The following are the thresholds from SCI for each AP.
The below thresholds provided is based on per AP model.
Table 4 SCI Thresholds
Resource Low Threshold Normal Threshold Range High Threshold Range
CPU Less than 25% Between 25% to 75% Greater than 75%
Memory Less than 2GB Between 2GB to 8GB Higher than 8GB
Hard Disk Less than 50GB Between 50GB to 100GB Higher than 100GB
