Configuring System Time
The controller uses an external network time protocol (NTP) server to synchronize the times across cluster nodes and managed access points.
To edit the system time:
- Go to System > General Settings > Time.
- Enter the NTP Server address that you want to use. The default NTP server address is ntp.ruckuswireless.com.
- Click Sync Server to enable an AP to join the controller and automatically synchronize its time every day.
- NTP Authentication: provide the NTP authentication which includes the Key Type, Key ID and Key
- Select the System Time Zone, from the drop-down that you want the controller to use. The default time zone is (GMT +0:00) UTC.
- Click OK.
