Creating NAT License Assignment
Licensing needs to be created on a per SZ Controller Cluster basis.
To create the NAT License assignment:
  1. Go to Administration > Licenses.
  2. Select the DP DHCP/NAT License Assignment tab.
  3. From the NAT License area, click Create.
    The NAT License form appears.
    • License Usage: Lists the details of license consumption and availability.
    • Data Plane: Select the data plane from the drop-down. To remove the Data Plane from the NAT license assignment, select Clear.
    • License Count: Enter the number of license for the data plane. Range: 1 through 20.
    • NAT Sessions/Flows: Lists the number of NAT sessions/flows.
    • Description: Enter a short description about the license assignment.
  4. Click OK.
You have created the NAT license assignment.
To edit or remove the license assignment on the data plane, select the assignment from the list and click Configure or Delete respectively.
