Configuring Switch AAA Server Settings
To configure and manage AAA servers, complete the following steps.
- Select Administration > Admins and Roles > AAA .
From
Switch AAA Setting configure the following.
Login Athentication
- SSH Authentication: Enable the option for secure authentication.
- Telnet Authentication: Enable the option to set Telnet authentication. This option requires SSH authentication to be enabled.
- First Pref: Select the first preferred authentication system.
- Second Pref: Select the second preferred authentication system.
- Third Pref: Select the third preferred authentication system.
Authorization- Command Authorization: Enable this option to assign the following authorization services:
- Level: Select the required privilege: Port Config, Read Only, or Read Write.
- Server 1: Select the authorization method for the first server.
- Server 2: Select the authorization method for the second server.
- Exec Authorization: Enable this option to authorize the user to access the privilege mode.
Accounting- Command Accounting: Enable this option to track the following accounting services:
- Server 1: Select the tracking method for the first server.
- Server 2: Select the tracking method for the second server.
- Exec Accounting: Enable this option to track the services in the privilege mode.
- Click OK.
Parent topic: Working with AAA Servers
