Configuring the SMS Gateway Server
You can define the external gateway services used to distribute guest pass credentials to guests.
To configure an external SMS gateway for the controller:
- Go to System > General Settings > SMS.
- Select the Enable Twilio SMS Server check box to use an existing Twilio account for SMS delivery.
- Enter the following Twilio Account Information:
- Server Name, type the name of the server.
- Account SID, type ths account number.
- Auth Token, type the token number to authenticate the external SMS gateway.
- From, type the phone number from which the message must be sent.
- Click
OK.
You have completed adding an SMS gateway to the controller. You will receive a guest pass key from your Twilio Trial account.
