Creating a Subscription Package
A subscription package defines the characteristics of a subscription that has been created for a registered user. These characteristics include the expiration date of the subscription.
If the user is connected at the time when his or her subscription expires, the user will get disconnected from the AP and any attempts to re-authenticate will fail.
  1. Go to Clients > Users & Roles.
  2. Select the Subscription Package tab, and then select the zone for which you want to create the package.
  3. Click Create.
    The Create Subscription Package page appears.
    Figure 111  Create Subscription Package
  4. Configure the options in the Create Subscription Package form.
    • Name: Type a name for the subscription package that you are creating.
    • Description: Type a description for this package.
    • Expiration Interval: Set the time unit to use for the package expiration. Options include: Hour, Day, Week, Month, Year and Never.
    • Expiration Value: Set the actual value to use in combination with the Expiration Time.
  5. Click OK.
You have completed creating a subscription package.
You can also edit and delete a package by selecting the options Configure and Delete respectively, from the Subscription Package tab.
