Logging Off the Controller
You must be aware of how to log off the controller using the web interface and the CLI.
The controller logs you off the web interface and the logon page appears.
You have completed logging off the web interface.
You can also use CLI commands to shutdown the controller.
To shutdown the controller gracefully, use the following command: shutdown and specify the number of seconds before controller shutdowns.
To shutdown the controller immediately, use the following command: shutdown now. The controller will shutdown in 30 seconds.
