Configuring DHCP Pool Settings
To configure DHCP pool settings:
  1. Go to Services & Profiles > DHCP & NAT > DHCP Profiles (DP).
  2. Select the DHCP prolife from the list for which you want to configure the pool settings.
  3. Select the Pools tab page.
  4. Click Create and configure the following:
    • General Options
      • Pool Name: Type a name for the pool configuration.
      • Description: Type a description for the pool configuration.
    • Policy Options
      • VLAN Range: Type the VLAN range. Range: 1, 2 through 4095. For example: 1, 2 or 2-3.
      • QinQ VLAN: Select the check box and update the following:
        • QinQ SVLAN Range: Type a SVLAN range. Range: 2 through 4095.
        • QinQ CVLAN Range: Type a CVLAN range. Range: 2 through 4095.
    • Assigning Options
      • Subnet: Type the IP address.
      • Subnet Mask: Type the network address.
      • Broadcast Address: Type the broadcast IP address.
      • Pool Range: Type the address range for the pool.
      • Exclude Pool: Type the address range that must be excluded.
      • Primary Gateway: Type the primary gateway IP address.
      • Secondary Gateway: Type the secondary gateway IP address.
      • Primary DNS Server: Type the IP address of the primary DNS server.
      • Secondary DNS Server: Type the IP address of the secondary DNS server.
      • Domain Name: Type the domain name.
      • Host Name: Type the host name.
      • Lease Time: Type the duration in Hours, Minutes and Seconds. Range: 1 through 86400 seconds.
    • Option43 Value
      • Click Create, the Create Option43 value form appears. Configure the following:
        • Choose the Space Name or click Create to configure Option 43 Space Name.
        • Enter a Description.
      • Click OK, you have configured Option43 value.
  5. Click OK. You have created DHCP pool configuration.
