Approving Mesh APs
You can approve mesh APs that join the network using wireless connection.
To approve mesh APs:
  1. Go to the Access Points page. On the upper-right corner of the page, select the Mesh option from View Mode. The mesh APs are listed. The Mesh Role field, displays the status of the APs.
    To view the list of APs pending for approval, click the Unapproved APs below the left pane.
  2. From the list, select the AP which is not assigned to a Staging or Default Zone and click Approve. The Approve Mesh AP form appears.
  3. From the AP Zone drop-down, select the zone.
  4. In Last 4 digit of AP S/N, enter the last four digit serial number of the AP.
  5. Click Approve, to manually approve the APs that join the network using Zero Touch Mesh (ZTM).
    After approval, Zero Touch Mesh (ZTM) AP changes mesh role to “approved”, and the AP will show up in AP list for waiting AP join.
