ZoneDirector to SmartZone Migration
SmartZone controllers are better equipped to handle large WiFi deployments such as within campuses and when customers are vastly distributed; therefore, Ruckus recommends that you migrate existing ZoneDirector deployments to SamrtZone controller deployments. You can migrate ZoneDirector AP configuration information to SmartZone controllers from the controller itself, using a migration tool.
The AP models should be supported by the controller.
Migration Support Matrix
| SZ version | ZD version |
| 3.5.x | 9.13.x |
| 3.6.x | 9.13.x, 10.0.x, 10.1.x |
| 5.0.x | 9.13.x, 10.0.x, 10.1.x |
| 5.1.x | 9.13.x, 10.0.x, 10.1.x |
![]() | CAUTION Do not power off the AP during the migration process.
