Follow these steps to export the last generated guest passes to a comma-separated value (CSV) file.
From the generate guest pass list, select the guest passes that you want to export
to CSV.
Click Export Selected.
Your web browser downloads the CSV file to its default download location.
Go to your web browser's default download location and look for a file named
guestpass.csv.
Using Microsoft Excel or a similar application, open the CSV file. The CSV file displays the details of the guest passes, including:
- Guest Name
- Key
- Remarks
- Generated
- Expiration Date
- WLAN
You have completed exporting the last generated guest passes to CSV.
Figure 119
A sample CSV of generated guest passes when opened in Excel
