Enabling LACP Support for an AP Group
Perform the following procedure to enable the LACP support for an AP group.
  1. From the left pane, click Access Points.
  2. Select an AP group from the zone and click .
  3. In the Configure page, enter the name of the AP group.
  4. Under Configuration, select R720 from the Select an AP Model list.
  5. Under General Options, enable LACP.
    By default, LACP is disabled. To enable LACP, both LACP and Override must be enabled.
    To support the LACP and LAG feature on Ruckus APs, ensure that the correct PoE mode is selected to bring up LAN1,2 ports. For example, PoE-at+ for R720, PoE-at for R710. The LACP and LAG UL throughput is limited to around 1Gbps.
  6. Click OK.
