New AP models and firmware updates are supported
without the need to upgrade the controller image by using AP patch files and diagnostic
scripts.
Go to .
Select the Patch/Diagnostic Scripts
tab.
Select the Upload to current node check-box.
Click Browse to select a script that you want to upload to the
controller.
Click Upload.
The script is listed in the
System Uploaded Scripts section.
If
you have uploaded a patch script, it is displayed in the
System Uploaded Patch
Scripts section with the following information:
- Name of the patch file
- Patch file description
- Supported AP firmware version
- AP model number
Click Delete to delete scripts.
Click Apply Patch to apply the patch file to the AP model or
firmware as appropriate.
You have successfully applied scripts to the controller AP.
