Enabling LACP Support for an AP
Perform the following procedure to enable the LACP support for an AP.
- From the left pane, click Access Points.
- Select an AP group from the zone.
Select an AP and click
- In the Edit AP page, enter the AP name.
- Under Configuration, select R720 from the Select an AP Model list.
Under
General Options, enable
LACP.
NOTEBy default, LACP is disabled.NOTETo support the LACP and LAG feature on Ruckus APs, ensure that the correct PoE mode is selected to bring up LAN1,2 ports. For example, PoE-at+ for R720, PoE-at for R710. The LACP and LAG UL throughput is limited to around 1Gbps.
Click
OK.
NOTEWhen you enable or disable LACP, the corresponding status is updated in the General tab of the Access Points page.
