Configuring Traffic Analysis Display for Top Clients
Using traffic analysis you can measure the total volume of traffic sent or received by clients.
Using traffic analysis you can measure the total volume of traffic sent or received by Clients. You must configure the Client settings to view the traffic analysis. You can view historical and real-time data of the Clients. The chart displays:
  • Bytes—Frequency and number of clients connected to the AP
  • OS Type—Types of OS the associated clients are using
  • Application—Throughput the applications use
To configure the Client settings:
  1. From the WLAN area, click settings . The Client settings form displays.
    Figure 21  Client Setting Form
  2. In the Show top box, enter the number of Clients for which the traffic must be analyzed. Range: 5 through 20.
  3. Select the Type radio button for the type of display you want to view. The choices are Chart or Table.
  4. Select the WLAN identification option to be displayed. The choices are Name, MAC, or IP.
  5. Click OK.
