Supported LLDP Attributes
The Link Layer Discovery Protocol (LLDP) is a vendor-neutral Layer 2 protocol that allows a network device (for example, a Ruckus AP) to advertise its identity and capabilities on the local network.
LLDP information is sent by devices from each of their interfaces at a fixed interval (default is 30 seconds), in the form of an Ethernet frame. Each LLDP Ethernet frame contains a sequence of type-length-value (TLV) structures starting with Chassis ID, Port ID and Time to Live (TTL) TLV. Table 2 lists the LLDP attributes supported by the controller.
LLDP information is sent by devices from each of their interfaces at a fixed interval (default is 30 seconds), in the form of an Ethernet frame. Each LLDP Ethernet frame contains a sequence of type-length-value (TLV) structures starting with Chassis ID, Port ID and Time to Live (TTL) TLV.The follwoing table lists the LLDP attributes supported by the controller.
Attribute (TLV) Description
Chassis ID Indicates the MAC address of the AP’s br0 interface
Port ID Identifies the port from which the LLDP packet was sent
Time to Live Same as LLDP Hold Time. Indicates the length of time (in seconds) that a receiving device will hold the LLDP information sent by the selected AP model before discarding it. The default value is 120 seconds.
System Name Indicates the name assigned to the AP. The default name of Ruckus APs is RuckusAP.
System Description Indicates the AP model plus software version
System Capabilities Indicates the AP’s capabilities (Bridge, WLAN AP, Router, Docsis), and which capabilities are enabled
Management Address Indicates the management IP address of the AP
Port Description Indicates the description of the port in alphanumeric format
