Creating Blocked Clients
You can deny access to the network for certain clients by using the block client access control feature.
  2. Select the Blocked Client tab, and then select the zone for which you want to block the client access.
  3. Click Create.
    The Create Blocked Client page appears.
    Figure 107  Create Blocked Client
  4. Configure the following:
    1. Client MAC: Type MAC address of the client that you want to block.
    2. Description: Type a short description for client.
    3. Click OK.
You have created the blocked client list.
You can also edit, clone and delete a list by selecting the options Configure, Clone and Delete respectively, from the Blocked Client tab.
