Logging Off the Controller
You must be aware of how to log off from the controller through CLI and from the web interface.
  1. From the Header bar, click admin and select Log off.
    The following message appears: Are you sure you want to log off?
  2. Click Yes.
The controller logs you off the web interface and the logon page appears.
You have completed logging off the web interface.
You can also use CLI commands to shutdown the controller.
To shutdown the controller gracefully, use the following command: ruckus# shutdown <seconds>, where seconds indicates the number of seconds before controller shutdowns.
To shutdown the controller immediately, use the following command: ruckus# shutdown now. The controller would shutdown in 30 seconds.
