Available System Logs for SZ100
The controller generates logs for all the applications that are running on the server.
Table 51 Controller applications and log types
Application Description
API Stands for application program interface (API), this provides an interface for customers to configure and monitor the system
AUT Manages the sessions in the controller's TTG module
CaptivePortal Performs portal redirect for clients and manages the walled garden and blacklist
Cassandra The controller's database server that stores most of the run-time information and statistical data
CNR An application that obtains TTG configuration updates and applies the settings to related modules
Configurer Performs configuration synchronization and cluster operations (for example, join, remove, upgrade, backup, and restore)
Diagnostics An interface that customers can use to upload Ruckus scripts for performing troubleshooting or applying software patches
ElasticSearch Scalable real-time search engine used in the controller
Memcached The controller's memory cache that stores client authentication information for fast authentication or roaming
MemProxy Replicates MemCached entries to other cluster nodes
Mosquitto A lightweight method used to carry out messaging between LBS and APs
NC The Node Controller, which monitors all of the controller's TTG processes
Northbound Performs UE authentication and handles approval or denial of UEs to AP
RadiusProxy Sets the RADIUS dispatch rules and synchronizes configuration to each cluster node
SMF An application that monitors the health of TTG processes
SNMP Provides a framework for the monitoring devices on a network. The SNMP manager is the system used to control and monitor the activities of network hosts using SNMP.
SubscriberManagement A process for maintaining local user credentials for WISPr authentication
SubscriberPortal Internal portal page for WISPr (hotspot)
System Collects and sends log information from all processes
Web Runs the controller’s management web server
