Create Precedence Profile
Clients are assigned to VLANs by various methods, and there is an order of precedence by which VLANs are assigned. The assignment is commonly done from lowest to highest precedence. You can also set precedence for Rate limiting attribute of the profile.
Each WLAN has a default precedence.
  2. Select the Precedence tab, and then select the zone for which you want to create the policy.
  3. Click Create.
    The Create Precedence Profile page appears.
    Figure 105  Creating a Create Precedence Profile
  4. Configure the following:
    1. Name: Type the name of the profile.
    2. VLAN Precedence: Use the Up and Down options to set the VLAN priority.
    3. Rate Limiting Precedence: Use the Up and Down options to set the Rate Limit priority.
      When SSID Rate Limiting (restricts total usage on WLAN) is enabled, per-user rate limiting is disabled.
    4. Click OK.
You have created the Precedence profile.
You can also edit, clone and delete a profile by selecting the options Configure, Clone and Delete respectively, from the Precedence tab.
