Creating an Application Policy
You can create policies around the applications that the controller will monitor, and there by control them.
Follow these steps to create and application policy:
  1. Click Create. The Create Application Policy page appears.
    Figure 100  Creating an Application Policy Rule
  2. Configure the following:
    • General Options:
      • Name: Type the name of the application policy.
      • Description: Type a short description for the application policy.
    • In Rules, click Create.
      The Create Application Policy Rule page appears.
      Figure 101  Creating an Application Policy Rule
      • Rule Type: Select one of the rule types from Denial Rules, QoS and Rate Limiting.
      • Application Type: Select whether the application type is user defined or system defined.
      • Application: select the application for which the rule applies and click OK.
  3. Click Create.
The Application Policy is created.
