Enabling Tunnel Encryption
You can use the tunnel encryption feature to encrypt data that needs to be transmitted to a private network, through a public network which does not support the protocol of the private network. This feature is available in vSZ-H and vSZ-E.
  1. Go to Services & Profiles > Tunnels and Ports.
  2. Select the Tunnel Encryption(DP) tab.
    The Tunnel Encryption (DP) page appears.
    Figure 138  Tunnel Encryption (DP)
  3. Select the Enable Tunnel Encryption check-box.
  4. Click OK.
You have successfully enabled tunnel encryption.
