Upgrading the Data Plane
You can view and upgrade the virtual data plane version using patch files. This feature is only supported on vSZ-H and vSZ-E.
vSZ support APs starting version 3.4. You must first upgrade vSZ before upgrading vDP, because only a new vSZ can handle an old vDP. There is no order in upgrading the AP zone or vSZ-D. During the vSZ upgrade, all tunnels stay up except the main tunnel which moves to the vSZ. Once the upgrade procedure is completed, allow ten minutes for the vSZ-D to settle.
Upgrade to R5.0 does not support data migration (statistics, events, administrator logs). Only the existing system and the network configuration is preserved. For more information, contact Ruckus support.
| SZ | VDP | Upgrade Procedure |
| 3.6.x | R3.6.x or R3.5.x or R3.4 |
| 3.5.x | R3.5.x or R3.4.x or R3.2.x |
| 3.4.x | R3.4.x or R3.2.x |
To Upgrade the Data Plane:
You have successfully ungraded the virtual data plane.
