You can control access to management interfaces from CLI or SSH.
Go to
Select the
Access Control List tab.
Select
Enable.
Click
Create.
The
Management Interface Access Control Rule page appears.
Figure 154
Configure the following:
- Name: Type the name that rule you want to create to access the management interface.
- Description: Type a short description for the rule.
- Type: Select one of the following
- Single IP: Type the IP address of the interface that can be accessed per this rule.
- IP Range: Type the range of IP address that will be allowed access.
- Subnet: Type the network address and subnet mask address of the interface that will be allowed access.
- Click
OK.
You have created the access control list rule.
You can also edit and delete the list by selecting the options
Configure and
Delete respectively, from the
