Configuring the SMS Gateway Server
You can define the external gateway services used to distribute guest pass credentials to guests.
To configure an external SMS gateway for the controller:
  1. Go to System > General Settings > SMS.
  2. Select the Enable Twilio SMS Server check box to use an existing Twilio account for SMS delivery.
  3. Enter the following Twilio Account Information:
    • Server Name, type the name of the server.
    • Account SID, type ths account number.
    • Auth Token, type the token number to authenticate the external SMS gateway.
    • From, type the phone number from which the message must be sent.
  4. Click OK.
    You have completed adding an SMS gateway to the controller. You will receive a guest pass key from your Twilio Trial account.
