Configuring AP Switchover
AP switchover is moving APs between clusters, not confined to clusters that enable cluster redundancy. For normal clusters, you can switchover APs with firmware later or equal to R5.0, no matter it is in Staging Zone or Non-staging Zone. But for a standby cluster in cluster redundancy, APs in Staging Zone can only be moved to another cluster by switchover.
To configure APs to swtichover clusters:
  1. From the Access Points page, select the AP from the list.
  2. Click More and select Switch Over Clusters. The specify Destination Cluster dialog box appears.
  3. Enter the Control IP or FQDN
  4. Click OK. A confirmation dialog to trigger the AP switchover appears.
  5. Click Yes. You configured AP switchover.
