Deploying an application control policy involves configuring a User Traffic Profile (UTP) with the policy, and then applying that profile to a WLAN.
To implement an Application Control Policy:
Go to
Services and Profiles > Access Control > User Traffic.
Click
Create. The
Create User Traffic Profile form appears.
Enter a
Name, and optionally a
Description for the UTP.
In the
Application Recognition and Control section, select an
Application Policy from the drop-down list. Alternatively, click
Create to create a new policy.
Click
OK to save the User Traffic Profile.
Go to
Wireless LANs.
Locate the WLAN for which you want to apply the application policy, and select it from the list.
Click
Configure. The
Edit WLAN [WLAN Name] form appears.
Expand the
Advanced Options section, and select a
User Traffic Profile you created from the drop-down list. Alternatively, click
Create to create a new UTP.
Click
OK to save your WLAN changes.
Figure 113
Create a User Traffic Profile (UTP)
Figure 114
Select an Application Policy to apply to this UTP
Figure 115
Apply the UTP to a WLAN
