Enabling URL Filtering in the User Traffic Profile
A User Traffic Profile (UTP) can be created to block or limit user traffic based on a number of factors, including URL filtering in addition to Source IP address, Port, Destination IP address, Protocol, etc. A UTP can be created to shape traffic according to a configurable Application Control Policy.
After the UTP is created, it can be applied to any WLAN from the Wireless LANs page.
  2. Select the User Traffic tab, and then select the zone for which you want to create the profile.
  3. Click Create.
    The Create User Traffic Profile page appears.
  4. In URL Filtering Control, select the URL Filtering Profile from the drop-down menu.
    You can also create a URL filtering profile by clicking Create. For more information, refer to Creating a URL Filtering Policy.
    You must select a UTP in which URL filtering is enabled, and also ensure URL filtering in enabled within the same WLAN configuration.
    Figure 120  UTP Page
You have successfully enable URL filtering in the UTP.
