You can assign a license bandwidth for a virtual data plane provided it is already approved. Each virtual data plane can be configured with only one bandwidth license.
Go to
Select the
License Bandwidth Configuration tab.
The
License Bandwidth Configuration page appears.
Figure 171
In
vSZ-D, type the name of the virtual data plane.
From the
Bandwidth drop-down menu, select the license bandwidth you want to assign to the virtual data plane. Default is 1 Gbps.
Click
Add. The vSZ-D with the assigned license bandwidth is displayed.
Click
OK.
The message
Submitting form appears, and the vSZ-D is assigned a bandwidth.
You have successfully assigned a license bandwidth to the virtual data plane.
