Configuring Packet Capture for APs
User can enable packet streaming feature on both wired and wireless interfaces on specified APs using web UI. You must enable this feature on a per-AP basis. It allows multiple users to execute AP packet capturing, but only a single AP can execute one capturing task at a time. For a single user can capture tasks in multiple APs, but batch operation is not allowed. Only users with full access permission can execute AP packet capturing.
To configure Packet Capture:
  1. From the Access Points page, select the AP from the list.
  2. Click More and select Packet Capture. The Packet Capture dialog box appears.
  3. Configure the Capture Mode:
    • Stream to Wireshark
      • Capture Interface Select the required wireless or wired interface
        • For 2.4 GHz/5 GHz, update the following details:
          Wireshark station IP: Enter the IP address.
          MAC Address Filter: Enter the MAC address.
          Frame Type Filter: Click the required options from Management, Control, and Data.
        • For Wired Interface, update the following details:
          LAN Port: Choose the LAN port.
    • Save to file
  4. Click Start..
