Disabling SmartZone Management on the ICX Switch
When SmartZone management is disabled on the switch, the switch will not initiate a connection with SmartZone even if a SmartZone IP address is available.
Enter the
sz disable command to disable SmartZone management on the ICX switch.
ICX(config)# sz disable
