Required RADIUS Attributes
For dynamic VLAN to work, you must configure the following RADIUS attributes for each user:
- Tunnel-Type: Set this attribute to VLAN.
- Tunnel-Medium-Type: Set this attribute to IEEE-802.
- Tunnel-Private-Group-ID: Set this attribute to the VLAN ID to which you want to segment this user.
Depending on your RADIUS setup, you may also need to include the user name or the MAC address of the wireless device that the user will be using to associate with the AP. The following table lists the RADIUS user attributes related to dynamic VLAN.
| Attribute | Type ID | Expected Value (Numerical) |
| Tunnel-Type | 64 | VLAN (13) |
| Tunnel-Medium-Type | 65 | 802 (6) |
| Tunnel-Private-Group-Id | 81 | VLAN ID |
Here is an example of the required attributes for three users as defined on Free RADIUS:
0018ded90ef3 User-Name = user1, Tunnel-Type = VLAN, Tunnel-Medium-Type = IEEE-802, Tunnel-Private-Group-ID = 0014 00242b752ec4 User-Name = user2, Tunnel-Type = VLAN, Tunnel-Medium-Type = IEEE-802, Tunnel-Private-Group-ID = 0012 013469acee5 User-Name = user3, Tunnel-Type = VLAN, Tunnel-Medium-Type = IEEE-802, Tunnel-Private-Group-ID = 0012
The values in bold are the users' MAC addresses.
