Configuring DHCP Pool Settings
- Go to Services & Profiles > DHCP & NAT > DHCP Profiles (DP).
- Select the DHCP prolife from the list for which you want to configure the pool settings.
- Select the Pools tab page.
Click Create and configure the following:
General Options
Pool Name: Type a name for the pool configuration.
Description: Type a description for the pool configuration.
Policy Options
VLAN Range: Type the VLAN range. Range: 1, 2 through 4095. For example: 1, 2 or 2-3.
QinQ VLAN: Select the check box and update the following:
QinQ SVLAN Range: Type a SVLAN range. Range: 2 through 4095.
QinQ CVLAN Range: Type a CVLAN range. Range: 2 through 4095.
Assigning Options
Subnet: Type the IP address.
Subnet Mask: Type the network address.
Broadcast Address: Type the broadcast IP address.
Pool Range: Type the address range for the pool.
Exclude Pool: Type the address range that must be excluded.
Primary Gateway: Type the primary gateway IP address.
Secondary Gateway: Type the secondary gateway IP address.
Primary DNS Server: Type the IP address of the primary DNS server.
Secondary DNS Server: Type the IP address of the secondary DNS server.
Domain Name: Type the domain name.
Host Name: Type the host name.
Lease Time: Type the duration in Hours, Minutes and Seconds. Range: 1 through 86400 seconds.
- Option43 Value
- Click
Create, the Create Option43 value form appears. Configure the following:
- Choose the Space Name or click Create to configure Option 43 Space Name.
- Enter a Description.
- Click OK, you have configured Option43 value.
- Click
General Options
- Click OK. You have created DHCP pool configuration.
