Extracting a WLAN Template
You can extract only WLAN-related configuration of an AP to a WLAN template.
Follow these steps to extract a WLAN template:
- From the Wireless LANs page, locate the zone from where you want to extract the WLAN template.
- Click More and select Extract WLAN Template, the Extract WLAN Template form appears.
- In WLAN Template Name, enter a name for the Template.
- Click OK, a message appears stating that the WLAN template was extracted successfully.
- Click
OK.
The extracted WLAN template can be viewed under System > Templates > WLAN Templates.
