Viewing a Summary of Wireless Clients
View a summary of wireless clients that are currently associated with all of your managed access points.
Go to The Wireless Clients page appears and displays a table that lists all clients that are currently associated with your managed access points.
To view only wireless clients that belong to a particular zone, click the zone name in the zone tree. The table refreshes and displays only the clients that belong to the zone you selected.
The following table lists the wireless client details.
Not all of the columns listed below are displayed by default. To display column that are currently hidden, click the gear icon in the upper-right corner of the table, and then select the check boxes for the columns that you want to display.
You can view the clients listed in the table in two view modes - No TTG (without TTG) and TTG (with TTG).
Click the
icon to export all the data into a CSV file.
| Column Name | Description |
| Hostname | Displays the hostname of the wireless client |
| OS Type | Displays the operating system that the wireless client is using |
| IP Address | Displays the IP address assigned to the wireless client |
| MAC Address | Displays the MAC address of the wireless client |
| WLAN | Displays the name of the WLAN with which the client is associated |
| AP Name | Displays the name assigned to the access point |
| AP MAC | Displays the MAC address of the AP |
| Traffic (Session) | Displays the total traffic (in KB/MB/GB/TB) for this client in this session |
| Traffic (Uplink) | Displays the total uplink traffic (in KB/MB/GB/TB) for this client in this session |
| Traffic (Downlink) | Displays the total downlink traffic (in KB/MB/GB/TB) for this client in this session |
| RSSI | Displays the Received Signal Strength Indicator (RSSI), which indicates how well a wireless client can receive a signal from an AP. The RSSI value is shown in decibels (dB) and displayed as either the real-time value or the average value over the past 90 seconds. |
| SNR | Displays the Signal-to-Noise Ratio (SNR), which indicates the signal strength relative to background noise. The SNR value is shown in decibels (dB) and displayed as either the real-time value or the average value over the past 90 seconds. |
| Radio Type | Displays the type of wireless radio that the client supports. Possible values include 11b, 11g, 11g/n, 11a, 11a/g/n, and 11ac. |
| VLAN | Displays the VLAN ID assigned to the wireless client |
| Channel | Displays the wireless channel (and channel width) that the wireless client is using |
| User Name | Displays the name of the user logged on to the wireless client |
| Connected Since | Displays the time from which the AP is connected to the wireless client |
| # of Events | Displays the number of client events |
| Data Rate (Up) | Displays the rate at which data is transmitted from the wireless client to the AP |
| Data Rate (Down) | Displays the rate at which data is transmitted from the AP to the wireless client |
| Auth Method | Displays the authentication method used by the AP to authenticate the wireless client |
| Auth Status | Indicates whether the wireless client is authorized or unauthorized to access the WLAN service |
| Encryption | Displays the encryption method used by the AP |
| Control Plane | Displays the name of SmartZone node to which the AP's control plane is connected |
| Packets to | Displays the downlink packet count for this session |
| Packets from | Displays the uplink packet count for this session |
| Packets dropped | Displays the downlink packet count for this client that have been dropped |
The client is automatically unauthenticated by the WLAN if the client is connected for 48 hours in the
Standard+Open/ Standard+MAC Auth authentication method, and for 12 hours in the
Standard+802.1x EAP authentication method.
